11-15-2009 03:29 PM
I'm trying to show some of the indicators only where appropriate -- the derivative graph when testing a resistor, and the semi-log excerpt graph for testing a diode. I'm also not sure I've excerpted the characteristic portion of the diode accurately. (The case structure bit is all the way off to the right; everything else works.)
Thanks!
11-15-2009 03:29 PM
11-15-2009 03:33 PM
I've looked at several similar threads that talked of the visible property, but I'm not sure I've used it correctly, and I can't test it from home -- no DAQ board.
Thanks.
11-15-2009 03:38 PM
11-15-2009 04:00 PM
I've created the property node = Visible, but I can't find how it works (or I can't understand the written directions). Any pictorial references you might mention? Thanks.
11-15-2009 04:43 PM - edited 11-15-2009 04:44 PM
here is an example:
the visibility function is a simple bool
11-15-2009 05:37 PM
11-15-2009 11:57 PM - edited 11-16-2009 12:00 AM
Harold Timmis wrote:the visibility function is a simple bool
I suggest to simplify further and delete the "select" and the two boolean diagram constant. If you wire the switch directly to the property node, it will function the same.... 😄
(see also).
11-16-2009 01:05 PM
11-17-2009 01:09 PM
