04-15-2016 11:50 AM
I'm having trouble setting up multiple user-defined variable axes with two 9501 c-series stepper modules running on a Compact RIO 9074.
I started with the "9501 Stepper Drive (Getting Started)" example, which worked fine with a single user-defined variable axis (Interactive Test-Panel, SoftMotion functionality on host).
I need to control 2 axes and I couldn't find any help on adding a second axis, so I came up with the following approach. My approach was to expand the FPGA VI in a way to add functionality for the second user-defined variable axis, so I did the following steps:
1. Add a new user-defined variable axis.
2. Add the same user-defined variables that the first axis had for the second axis.
3. Make a copy of the global variables that the first axis needed in order to have independent global variables for the second axis.
4a. Expand the FPGA VI while-loops with the same circuits for axis 2 and make sure those circuits for axis 2 use their own global variables, the right modules, their user-defined variables and change the axis index from 0 to 1 (not sure how exactly the axis index is defined).
4b. I also tried to copy all the loops so each axis had their independent loops. Then adapt global variables, modules, user-defined variables, axis index.
The FPGA VI compiles and runs, but when I get to the Interactive Test Panel for both axes and try to enable them, it throws a -70228 error (controller unable to confirm that the drive is enabled).
Am I doing something wrong? Is there maybe a more simple way to get two 9501 modules working with SoftMotion?
I can provide the projects of my two edited examples (same loop/independent loop), if needed.
LabVIEW setup:
LabVIEW 2014f1
FPGA Module 2014
Real-Time Module 2014
SoftMotion 2014f1
cRIO-Drivers 2014f1
Xilinx Tools 14.7 2014
I hope that somebody can help me, thanks in advance.
Solved! Go to Solution.
04-20-2016 05:03 AM
hi,
maybe your project will provide more information. From your description I don't see anything wrong.
Did you enable the axis 2 in its properties?
Best,
Anna
04-22-2016 02:55 AM
I managed to get it working.
I was missing that some motor-control SubVI's in the FPGA VI have defaulted their axis index to 0. I didn't even see they worked with an axis index until I looked into the block diagram of those.
So what happened was that my routines on the second axis immediately disabled the first axis because of the wrong axis index.
Setting the axis index to 0 and 1 (axis 1 and axis 2) for every single motor-control SubVI was what was missing.
09-06-2017 10:38 AM
Hi Darenk,
Could you help to share the example code of multiple axes with 9501 C-Series modules running with SoftMotion on a cRIO 9074? It is helpful for good reference
Thanks a lot
Vivian
