06-30-2014 01:38 AM
Is there any way to get the list of Lan Users in Labview without using net view Command in System Exec.vi....
Thanks in Advance....
06-30-2014 04:30 AM
I am not sure anyother function exist to perform what you ask (as far I know). Is there any challenge in using the System Exec.vi?
06-30-2014 02:11 PM
No need to re-invent the wheel. Use the command line tools that are made for this type of thing, unless there is a good reason you can't use them.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
07-01-2014 03:49 AM
Of course there are other ways such as calling WinAPI functions. But, those APIs are anything but trivial to interface directly to from Call Library Nodes, and sometimes rather obscure. The only feasable thing to go this route would be to write a DLL in C that calls these APIs and provides a more concise and LabVIEW friendly interface. Not something many LabVIEW programmers would want to do, nor would be able to.
Give me SystemExec instead. That simply works without days of tinkering with C code and lots of crashes during debugging.
