How to generate random numbers from 1 to 5
-1110340081
(2,470 Views)
Random integers 1,2,3,4,5 or random floating point numbers 1...5?
What have you tried so far? Where did you get stuck?
(2,467 Views)
Accepted by topic author fewfew
thank you i have finished
(2,458 Views)
(You should not mark a post as solution unless it actually contains a solution to the original problem)
Do you want to share your code? Did you test to make sure that all numbers equally probable?
(2,446 Views)
