06-08-2006 05:08 PM
06-08-2006 05:25 PM - edited 06-08-2006 05:25 PM
Message Edited by BrianPack on 06-08-2006 05:27 PM
Message Edited by BrianPack on 06-08-2006 05:28 PM
06-08-2006 05:27 PM
06-08-2006 05:30 PM
Hi, there are many ways to do it, one way is to use a for loop, and use a shift register with the add function to generate the array, and storing it in an array, or plotting it.
I post an example
I hope this helps. Please let me know if you need more help
03-19-2015 08:53 PM
You can also use the Ramp Pattern function if it is available on your target.
03-19-2015 09:00 PM - edited 03-19-2015 09:01 PM
Wow. Digging up 9 year old posts to add ideas to.
With only 2 posts, "Confused undergrad" might still be confused, but hopefully is no longer an undergrad.
