05-07-2012 06:57 AM
HI, I am using a control palette to display my video images using image display. However, the size is alway out of proportion. How do i show the whole image in the small box screen size. Basically how to fit to size for the images?
05-07-2012 07:10 AM
This should do the trick:
Norbert
05-07-2012 07:11 AM
You have that option in the Image Indicator itself. Right click the indicator you will get an option something like "Fit Image with Indicator" (Sorry I forgot the Actual name )
05-07-2012 07:28 AM
The name is "Zoom to fit". Thanks.
05-07-2012 07:29 AM
Ah.. Got it.. Thanks.. It was long before I was playing with those stuffs. 🙂
11-08-2013 04:09 AM
Is there a trick for LV2010? A "Zoom to fit" function is nowhere to be found...
