I have to do transfer files from the Local PC to a remote location PC via FTP. Before I transfer the files, I have to check for disk space on the Remote PC. If space is sufficient, then only I have to transfer the files, if not a Message display has to be given as to no Space. What should i use to find out the disk space on Remote PC? Thanks..
If you use the File I/O >> Advanced >> Volume Info VI and pass in the path to the remote drive in UNC format then you should get the amount of used & free space.
