How to filter an fxp signal
Iam using crio 9024.
i have a signal which i have imported from fpga to real-time vi.
its data type is fxp.
i wish to filter this signal (lowpass) and perform spectral analysis.
however, nothing i seem to do works.
i use point by point filter but its output a single value. and hence even on conversion to dynamic data, filter express vi doesnt work.kindly help.
which vi can i use and how?
(2,928 Views)
Hi Bgmnt,
why don't you convert the FXP to DBL - as is expected from nearly all signal analyzing functions?
Usually it helps to get an answer when you attach your VI or even a simplified version of it. Don't forget to include some example data as well by setting default values in controls/indicators…
(2,892 Views)
I did.
however,
when i connect the dbl output to filter (signalexpress) , and connect a spectral measurement(fft in signal express) , no output is visible on the ftt indicator.
presumably because its takin in single data point at a time
(2,878 Views)
Hi Bgmnt,
presumably yes…
I repeat from my previous post:
(2,873 Views)
