Reply
How to export wave form data to excel with specified location?
How to export wave form data in excel with specified location,
i.e. Specified column,
How it is possible?
Thank you.
Message 1 of 6 (619 Views)
Reply
Re: How to export wave form data to excel with specified location?
if I read this item and your previous item, then I guess you need an excel toolkit? Smiley Wink
Can't you just use a *.csv file?  Or do you want to do your reporting in Excel as well.
Kind regards,
Bjorn
Kind regards,
- Bjorn -
Have fun using LabVIEW... and if you like my answer, please pay me back in Kudo's Smiley Wink
LabVIEW 5.1 - LabVIEW 2012
Message 2 of 6 (611 Views)
Reply
Thank you for immediate responding,
I want send wave form data with specified column..In excel sheet
i.e.  wave form data is 2 dimensional, For Example i want write data in 5 row Dth column onwards,
and 5 row Eth column...
How it is possible...?
Thank you.
Message 3 of 6 (603 Views)
Reply
The best way to do this is to use the office report generation generation toolkit
You will have to do some translation of the data in order to get it all lined up.  But I have found that with a little practace I can make vi's that are more useful than the best VB script with these vi's.
Message 4 of 6 (596 Views)
Reply
Without tool kit is it possible....?Smiley Wink
Message 5 of 6 (587 Views)
Reply
Yes, it's possible -- it's just not as easy as most things are in LabVIEW (which is why we created the Report Generation Toolkit).
You'll want to look into either the Excel ActiveX interface or the Microsoft.Office.Interop.Excel .NET assembly in order to automate Excel.  This code snippet is an example of using the .NET assembly to create a datatable and graph in Excel:
If you have the Report Generation Toolkit you can get the same effect using the MS Office Report Express VI and your code would look like this:
Good luck,
Simon
Message 6 of 6 (566 Views)
