04-01-2013 03:58 PM
I mentioned the tab control in passing. I get the error message regardless of tab control or not.
I have one flat box surrounding three objects in my VI and this box is NOT inside the tab control at all. It is sitting outside.
I still get this error shown in my previous post.
04-01-2013 04:19 PM
Post your VI, or at least the part that gives the error.
04-01-2013 08:04 PM
Hi Darin
The main VI is untitled18.vi
It calls a bunch of sub VIs all included in the zipped file below. I also included one sample data file (file1.txt).
Run the main VI and select file1.txt.
Data and everything plotted is fake.
04-01-2013 09:28 PM
I stripped everything out except the exporting. The main problem was the position of the tab, negative values are a problem for the image subset VI. I moved everything close to the origin and made a few mods to export the images.
04-02-2013 02:16 AM
Thanks Darin. Could you please save in 2011 version. I don't have labVIEW 2012.
04-02-2013 09:17 AM
Here it is in LV11. Notice that I do not discriminate and simply export all of the decorations, which includes the Free label in the first tab. You should be able to sort this out with the other information in this thread.
09-27-2018 02:31 PM
I think it should be easy like that "Array>Create>Invoke Node>Get image"
