NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Drew
How to export Waveform data to Excel table and chart?
I am reading data using AI Acquire Waveforms. Data is read from multiple channels on a PXI NI 6052E. On the LV front panel the data is displayed in a waveform graph. I want to export the waveform data to an excel spreadsheet using the toolkit VIs such as Excel Easy Graph, and to paste the actual waveform data to spreadsheet cells. I'm having trouble executing this and trying all sorts of different ways. Is there a simple example for working with the waveform data type to do this?
Active Participant
Labviewguru
Re: How to export Waveform data to Excel table and chart?
with the "Export Waveforms to Spreadsheet File.vi" function in the Waveform>waveform tools palette.
Member
Drew
Unfortunately my situation is not as simple as using this VI. For example I need to add waveform information to a report which includes a lot of other workbooks in an xls file. I see that I could open up this file VI and copy out what part of the functions I need, or I could write the info to a temporary workbook, and then copy it to my report, but I am looking for other tools or methods that can get the waveform data. Am I wrong that my only options here would be 1) make my own VI out of the simpler export VI, 2) export the waveform and then copy it into the real report?
Active Participant
Jeremy Braden
There is no VI that will take the image of a LabVIEW chart and put it in excel. Passing the data is doable and there are several examples that show how that is done. The only workarounds that I could think of are the ones you suggested.
Jeremy
Member
Preetisar
It is possible to take the image of a LabVIEW chart and put it in excel. Go to Examples>>office>> MS Graph Reports
Knight of NI
RavensFan
Did you happen to notice you are responding to a thread that is nearly 9 years old?
Member
Eleftherios
better late than ever....:smileyvery-happy:
Member
Preetisar
No i didnt.... Just felt that I could chip in something..so juss did it.. thanx :smileyhappy:
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
