01-30-2005 09:29 PM
01-31-2005 11:22 AM
02-01-2005 08:51 PM
02-03-2005 12:00 PM
09-22-2016 10:16 AM
Hello, I am new to labview and I am trying to get a flat frequency response using swept sine technique. I am using NI-USB 6225 (80 channel) and I am also using a VI that was available for download online. The picture below is how the VI looks like.
I am using a bone conduction transducer (BCT) as my excitation to sweep the frequency from 100 to 10kHz and receiving a signal back to a contact microphone. I have the given frequency response curve (not the actual data but from a datasheet) of the BCT and I wanted to make the frequency response of the BCT flat by adding an inverse response.
I was wondering where the best possible place would be to add this?
(If you need more clarification, let me know!)
James
09-24-2016 09:05 AM
we are in the frequency domain and assume a linear system:
FRF (w) = Response_measured (w) / Stimulus(w)
but your Response_measured actually is folded with the FRF_sensor so
Response_measured (w) = Response (w) * FRF_sensor (w)
FRF_compensated (w)= Response_measured (w) / FRF_sensor (w) / Stimulus (w)
PS: How to set formulars here in the forum?? (TEX syntax prefered 🙂 )
