09-19-2008 07:57 PM
09-19-2008 09:48 PM
You are using "insert into array" which increases the array by one. To place a new value into an existing array element, keeping the array size constant, you would use "replace array subset".
You should really start out with a few simple tutorials. A lot of your code makes no sense at all.
For example:
09-19-2008 10:12 PM
Here's a quick draft that shows some of the basic ideas (LabVIEW 8.5).
The value of the random number is placed in one of three array positions, depending on the value of a radio button.
09-19-2008 10:31 PM
Thanks for the reply. The code is a bit haphassard, sorry bout that. The local variables are there to zero those variables off before the loop starts. The property nodes refer to something else that I hadn't quite finished. The to zero them off before the while loop kicks in.I tried to wire to the array terminal but that didn't seem to worl. Will try the shift register. the case structers and buttons are there to try and lock in the value. I think I am trying to do what the select function does which I have just seen.
While I have tried to do tutorials to get to grips with labview, at this stage I really don't have time, so sorry if things here seem messy and unprofessional.
09-19-2008 10:37 PM
