How to enable and disable button?
  I am new to LabView. So please forgive me for putting so simple question on this forum. I have one RUN button,one STOP button in my Vi. When Vi is running if I press RUN button some action initialise and RUN button goes in disable mode. When I press STOP button my vi stops and STOP button goes in disable mode. When I again execute my vi this 2 button (i.e RUN and STOP) are still in disable mode. What I require is that irrespective of state of button in first execution,the state of button must be always in enable mode whenever I execute the VI.
  Second problem is that when i press RUN button it goes in disable mode,if user again press the RUN button(now in disable mode) it should not enabled unless and until user press STOP button or vi is executed once again.
Thanks & Regards:-
Mike
(26,903 Views)
Hi Mike,
For your first question, answer is simple. You ve to programatically reset the buttons back to Enabled mode.
For your second question, the user cannot click on a Disabled or Disabled & Grayed out button and initiate a correspomding, unless & until that button is programmed with its Mouse Down/Up event using the Event Structure method of programming.\
See the attached VIs in LV 7.1.
Repost here for more doubts or queries.
- Partha ( CLD until Oct 2024 🙂 )
(26,897 Views)
Hi
The real question is : what do you mean with disable mode?
Normally when you push a button the boolean value switches and if this button has the latch action enabled (mechanical action) it stays in that value until the program reads it.
disabling buttons is something you do in the program and only if you really want to do it.
greetings from the Netherlands
(26,896 Views)
Thanks Partha !!!! This is what i exactly want.
(26,892 Views)
Say it with stars ! Smiley Wink
(26,887 Views)
See the attached VI for a bit of modification of the booleans being put to Latch mechanical action.
Thisis what Albert Geven had mentioned in his post.
Do you need something similar to this ?
(26,885 Views)
