Hi all,
I need to have two timing functions running in the same VI... But, I havent found a good way to do this....
I need one loop to control a cycle that turns a signal on and off, fx. 2min on and 3 off. (must be configurable).
At the same time, I need to sample data at a defined interval, independent of the other loop, every 10sek. (these data are logged in a file).
(All timmer intervals must be configurable).
To avoid doing it more complicated that it needs to be, I hope that I can have some inputs of how to do/solve this...
(without doing too many first time mistakes).
Martin.
