09-02-2014 12:13 AM
HI
I want to draw a Bar Chart using Waveform Chart. i was able to generate bar plots according to the values. i want to display text depicting the name of entity each bar is referring to. the text will appear near each bar plots. im attaching an image below to make the picture clear. Refer to the text marked in red circles. this is how i want to display my text
i searched many properties for it. But there is some way to do it. Because the image was generated using LabVIEWb
Thanks in advance,
Rahul Garg
Solved! Go to Solution.
09-02-2014 02:45 AM
09-02-2014 05:40 AM
WOW !
Thanks friend
annotations worked perfectly to display text near bar plots
10-24-2016 02:53 PM
How did you get the text sideways?
