07-21-2014 12:33 AM - edited 07-21-2014 12:37 AM
A similar question was asked in 2005, I figure I would ask again in 2013 Labview edition.
How do I display Block diagram primatives labels (not just VIs) ? I see the only way to know what that primative is for by using Context Help.
Any advices ? Thanks.
On second thought, I also would like to know how to zoom in a block digram using Mouse scroll, I don't have a very good eyesight and this might be helpful !
07-21-2014 01:08 AM
Did you try the Right click>Visible Items> Labels ?
There are lot of ideas floating around to make a zoom option for BD, you may check the response here.
I would suggest you to decrease your screen resolution for better sight on the BD objects 🙂
07-21-2014 01:26 AM
Bingo, Right click -> show labels .... But... is there any way to make this behavior default ?
07-21-2014 01:33 AM
Go to Tools> Options> Block Diagram, you have the option there.
07-21-2014 01:35 AM
Yes yes, the guy in 2005 suggested this option but unfortunately the labels for primative block diagrams are not enabled by this option
07-21-2014 01:54 AM
Yes unfortunately it doesn't seem to work with primitives but only on Sub VIs.
07-21-2014 06:23 AM
It also helps if you highlight the right option.
07-21-2014 06:55 AM
SpoilerYou highlighted the Subdiagram Label option, not the subVI label option.
Yes, my bad. Thanks for pointing me out.
07-21-2014 08:27 AM
Ctrl+A then Right-Click Visable items will show lables for all primitives on the ROOT Block Diagram. You can Click Then Shift click to select multiple items on sub-diagrams and show all of thier lables at once too. with 2012 and later.
07-21-2014 12:55 PM
That's a good trick, a little inconvenient but i guess I have to get used to it , thanks
