05-13-2013 02:36 AM - edited 05-13-2013 02:37 AM
Did you even read my post above? I said to make it an indicator and use a "mouse down" event on the LED instead of a "value change" event. Did you try?
Why should it be a control? Can you explain?
05-13-2013 03:18 AM
Hope this is what you are looking for
05-13-2013 03:19 AM
Hi altenbach,
I tried that it was working. Thank u very much
If that LED is in a Cluster & i make that has indicator, everything present in that cluster changed to Indicator. I want to make only that LED as Indicator. How to overcome from this?
Thanks & Regards,
Harish. G.
05-13-2013 04:38 AM
Hi Ranjeeth_Singh,
Thanks for ur help. That's not answer. Altenbach gave me solution. See that one!!
Thanks & Regards,
Harish G
