01-06-2015 07:50 PM - edited 01-06-2015 07:50 PM
Hello!
I am calling a DLL which returns a pointer to a structure consisting of a pointer to a string, a 32 bit integer, and another pointer to another string.
I have managed to use MoveBlock to return a cluster of these three things and that works fine.
But now I need to read the two strings that I have pointers to which are not fixed length. MoveBlock has a size input but how do I determine how long the strings are?
01-06-2015 08:41 PM
Try this:
...\vi.lib\Utility\importsl\GetValueByPointer\GetValueByPointer.xnode
Just wire a string constant to the Input Type. If I recall correctly the terminating null (assuming C strings) will be included.
Sometimes I just MoveBlock one byte at a time until I reach a null or a specified maximum size.
01-06-2015 08:46 PM
Steve,
You can use GetValueByPointer without needed to know the length of the string before hand. The community example for dereferencing pointers mentions that this is the perferred method for strings
<LabVIEW>\vi.lib\Utility\importsl\GetValueByPointer\GetValueByPointer.xnode
01-07-2015 07:31 AM
Thanks. I tried GetValueByPointer but it would not work in an exe. I got an error of some kind. I think it was an error 7 file not found. I can revert the code back to when I was using that and check again when I have access.
As for reading 1 byte at a time, do I just read until I get a 0 or whatever the NULL is in C? Also would performance take a hit?
01-07-2015 09:16 AM
Thanks Darin. You gave two valid solutions.
The one that I am going with is reading a byte at a time until I reach the NULL. I ran into a separate problem using the xnode when running as an exe. I probably won't have time to investigate that further but it was something about file not found.
I am glad to see that all my favorite avatar's are still here answering questions! I have been really busy doing non-LabVIEW things so I have not had as much time for my favorite forum.
01-07-2015 11:40 AM
If you configure a CLFN to call StrLen (http://zone.ni.com/reference/en-XX/help/371361K-01/lvexcode/strlen/) you should be able to get that info. Depending on the format there are many other support functions you can call that are more well documented (http://zone.ni.com/reference/en-XX/help/371361K-01/lvexcode/support_manager_functions/) and less well documented (<LabVIEW>/cintools/extcode.h). If I'm not mistaken you should be able to call anything in extcode.h (except the macros of course) from a CLFN, just like you're using moveblock.
01-08-2015 07:06 AM
Awesome, thanks. I could not get this to work when I had MoveBlock configured with destination as a string. It read more than it should have and caused LabVIEW to crash. I probably had it configured wrong but what I ended up doing was to initialize a U8 array to the size returned by StrLen then use MoveBlock to fill this array, and convert the array to a string.
