How to delete a resource that didn't show up in MAX configuration tree?
I want to delete the TCPIP0 resource. The help says to right-click it in the configuration tree and to select DELETE. The problem is the TCPIP0 resource doesn't show up in the configuration tree. Is there another way to delete it from MAX database?
Note that it also doesn't show up in VISA interactive controls.
Ben
(2,082 Views)
If you want to delete resource names individually, delete their aliases from visaconf.ini (the file that stores the aliases), and then refresh Measurement & Automation Explorer (MAX) to view the changes.
(2,069 Views)
