01-02-2009 06:55 AM
I mentioned in earlier posts that I'm one of the Geeks of LABVIEW (I mainly work using .NET languages). However, having a motivated community made me dare to do some automated measurements with LABVIEW.
I capture analog voltage corresponds to strain on a test specimen (I utilize NI DAQ 6008 and signal conditioning circuit I made, so this is the easy way as many of you already know). I want to give it some stunning look by having 3D surface that is bent (deflected) according to the corresponding analog voltage.
If someone could create a simple VI with perhaps having a slider and the 3D surface on 3D picture control for testing deflection, This would be a dream that comes true.
Thanks to all of you in advance.
01-02-2009 07:11 AM
Hi there
Open the Example Finder (Help->Find Examples) and search for "3D". Start with "3D Surface Example - Fluctuating Sine Wave.vi". This will give you a good start.
01-04-2009 04:59 AM
Thanks Chris for your valuable help. It did help alot. I only hope to implement 3d deflection of "3D Picture Control". Maybe by using mesh and change the dimesion programmatically.
Thanks again and all help is appreciated in this regard.
01-05-2009 08:31 AM
01-05-2009 08:37 AM
VBCoder wrote:
Is it that difficult to achieve such a task? does anyone recommed aborting the idea and replace it with charts?
The 3d picture control is;
1) quite complicated for the caual developer
2) Still new enough that I have not tried it in an app (due to reported bugs)
So I can't step up and say "take a look at this thread".
I'd first try to do it using a the CW 3d graph (since I know that critter) but even for that approach I'd need a good expresion to relate the strain to deformation.
Ben
11-25-2010 04:14 PM
Hi, I've seen this therad:
http://zone.ni.com/devzone/cda/tut/p/id/7130
The article has the 3D deflection that I seek. If anyone managed to generate such a thing, I'll be so grateful.
Have a nice day.
