05-16-2012 07:44 AM
How to change pic.(power_1) to pic.(power_2)?
05-16-2012 08:01 AM
if you want to do that you can't use a waveform you have to use XY an graph. Only XY Graphs can have plots that have many Y value for the same X value.
Hope this helps
Epictetus
05-16-2012 08:07 AM
With the XY graph that was suggested, you can see an example here: http://zone.ni.com/devzone/cda/epd/p/id/2207
05-18-2012 09:14 AM
Thank you for your help, but I use ' the FFT power specturm.vi' to make the waveform ,so I can't get the X and Y value.
I holp to get more help, Thanks again !
05-18-2012 09:24 AM
Well of course you can get the Y array and then you can easily build the X array base on the To and dt.
Let me know if you need help to do that.
Epictetus
05-18-2012 09:38 AM
Thanks so much, can you give any examples for it.
Use FFT power specturm.vi to get X(amplitude) and Y(frequency) .
05-18-2012 10:59 AM
YES I need your help for that
05-18-2012 12:13 PM
All you need to do to get the X array is to use the Ramp Pattern function. In your case you'd want the Ramp by Delta instance since you have a t0 and a deltaT.
