07-07-2015 02:33 AM
07-07-2015 07:06 AM
I would use the phase input to the square wave. Give each waveforms either a time or phase input by adding it to your cluster. If you choose time, then calculate the phase (time*frequency*360= phase in deg).
Also, the reset signal needs to be true to set the phase in that VI.
07-09-2015 01:03 AM
Thank you Josh. I have limited knowledge about signals and their manipulations. What is phase for signal? Is there any reinforcement that I can consult about signals/waveforms?
How can I implement your suggestion?
What is the problem with the vi that I sent? I really do not understand. Changing to for the second waveform does not affect it, why?
07-09-2015 02:00 AM
07-09-2015 07:37 AM
I got it GerdW, thank you. How could I manipulate the phase to make a time delay? For instance, I want to generate the first signal immediately as the vi runs, but I want to start generation of the second signal after let's say 10 ms after the first one starts. How could I do it via manipulating of phases? Is there an equation (relation) between phase and time delay?
07-09-2015 07:39 AM
Hi Egemen,
Yes: sample rate…
When you want to start one waveform laterthan the other I would just prepend some additional samples (with value=zero) to the 2nd waveform…
07-09-2015 07:48 AM
Hi GerdW,
What is the equation of sampling rate in which I can use phase as a parameter? I do not know this equation. I am a newbie at generating signals, trying to learn.
How can I determine the time by use of empty samples? How can I determine the sample number of these empty values?
07-09-2015 07:53 AM
07-10-2015 01:36 AM - edited 07-10-2015 01:40 AM
Thank you GerdW.
Josh, I do not think that I can solve my problem with manipulating with phase parameter. It is a period, so its changes affect in just one cycle. I need shifting the second signal far away, let say 5 cycle forward from the first one. How can I do that shifting?
By the way, I just realized that the waveform graph "ignore time stamp" function is on, I think that's why I saw them coincident.
07-10-2015 01:38 AM
