12-22-2008 12:21 PM
Just out of curiousity, how can the customer be both tall and short?
There should only be 3 selections, correct?
So the array would be 3 columns wide:
(Male) (Tall/Short) (Size)
12-22-2008 12:26 PM
Cory K wrote:Just out of curiousity, how can the customer be both tall and short?
Ever been in a Hall of Mirrors?
12-22-2008 06:31 PM
brute force? could you please send me the example cause i have tried many methods but i just cant get the final result. i have attach what i have done so far.
12-22-2008 06:35 PM
12-22-2008 07:13 PM
12-22-2008 11:59 PM
12-23-2008 03:27 AM - edited 12-23-2008 03:28 AM
Wire it directly. Right click on the tunnel and select Disable indexing.
12-23-2008 03:52 AM
thank you very much mathan. it solve the problem. erm... if lets say i have 4 buttons in a cluster then originally they are able to perform as control and produce the array list. but now i created a check box. when i check it then all the buttons will be selected and it will display and create all the elements in the list but i lost the ability to manual select the buttons myself. how do i solve it? i tried to use the true or false case structure but the cluster only can be use as indicator and not as control at the same time.
12-23-2008 03:55 AM
12-23-2008 09:02 AM
