How to create an array list of strings by using buttons?
HI, i need some guidance from you guys to help me out. How do i create a list of array whenever i click on a button it will generate a string and place it in an array row by row. if i dont click on the button it will ignore it and wont create the array. i have tried many technics such as looping and building array but it wont generate the list that i want.
Message 1 of 22
(4,176 Views)
I am not sure if I have understood your question correctly, but is the attached what you were looking for?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 22
(4,164 Views)
hi adnan, thank you for the reply. i tried to open the example.vi but it seems to have an error. are you using labview v8.6? cause im using labview v8.2.
Message 3 of 22
(4,159 Views)
Here you go...in 8.2.
Adnan Zafar
Message 4 of 22
(4,156 Views)
when press run the result dint show anything? is it suppose to be empty? cause i click ono male tall short l size and xl size but the array was blank. what should i do?
Message 5 of 22
(4,153 Views)
Hi adnan thank you very much for the example. i got it to work. but its close to what i want to do. instead of click on it everytime to generate a list , im trying to make it automatically generate. means i just have to select (click) on male tall short s size m size l size just one time and it will automatically generate the list of arrays with all the elements
Message 6 of 22
(4,149 Views)
All of what elements? Are you trying to create all the permutations? Are there specific combinations you're trying to create? Your original picture seems to imply that you want to create 4 combos:
  • Male, Tall, Short, Small
  • Male, Tall, Short, Medium
  • Male, Tall, Short, Large
  • Male, Tall, Short, Xtra Large
If that is all you want, you just need to create an array: Build Array. If that is not what you want, please explain further.
Message 7 of 22
(4,128 Views)
all of the elements that are being selected by the on button. nope not all the permutations. actually its like this. i will explain the workings here:
Step 1 : click on the buttons for example click male, tall, short, small , large
Step 2: RUN
Step 3: the array list will show MALE, TALL SHORT, SMALL
                                                 MALE, TALL, SHORT, LARGE
             it will show it automatically
Message 8 of 22
(4,122 Views)
I want to create something kind of a like a family tree. which will automatically create a list based on the buttons i have selected. this is an example of the selected buttons and the actual result that i want to get.
Message 9 of 22
(4,096 Views)
Well, that is all possible unique non-ordered permutations. You can do this in a brute-force method using 4 nested for-loops. It's not clear how much LabVIEW experience you have - I'm guessing very little. What have you tried so far? I can post a brute-force method that I whipped up, but I'd like to see what you've done so far. The brute-force method will work, but it's not easily scalable.
Message 10 of 22
(4,056 Views)
