07-17-2006 06:48 AM
07-18-2006 03:39 PM
thescar--
OK, I couldn't remember if you were using the counters or the digital/PFI lines (this is what you should be using)...either way, you should be fine with the hardware that you have. The 6229 has 2 counters and 48 DIO/PFI lines. Best of luck.
John H.
07-21-2006 06:03 AM
07-21-2006 11:02 AM
thescar
That is understandable. So that you are comfortable with what you get, and to make sure you get the right product for you, I would suggest calling one of our sales reps at (888) 280-7645...they will ask you about your application and make sure you get the right product and you can ask them any questions you may have. If you'd like to do a little research, or maybe order online, you can go to http://www.ni.com/dataacquisition/ and follow the links about what you need and it will guide you to the right product. Anyway, let us know if you need anything.
Regards
John H
07-25-2006 05:34 AM
07-26-2006 02:17 PM
Hello G.,
The PFI lines (including those used for the counter) of the NI 6229 can drive a maximum of 24 mA. You mentioned that your lamp uses 20 mA, so I would not recommend connecting both things to this line. Instead, you can use both counter 0 and counter 1 in the same pulse generation task and connect one device to each line. The pulses will be synchronized.
Hope this helps!
Laura
