06-27-2006 12:40 PM
06-28-2006 11:50 PM - edited 06-28-2006 11:50 PM
Hi COmpa,
Do you think is possibile to connect it to the serial port of the pc
and create via Labview the Trigger?
The strobe needs a +5V, 20mA,10-100µsec pulse to be triggered.
I think the 9-pin serial port on a PC swings between +/- 12V - if that's OK for your trigger, then a pulse of precise duration might be generated by configuring the port for serial output, a suitable baud-rate, careful selection of start or stop bit, and then sending a single byte byte where all bits are the same. I've never done this, but I think it's possible!
If the +/- 12V is a show-stopper, then consider using a parallel-port instead. Its pins swing between 0 and 5V.
http://zone.ni.com/devzone/conceptd.nsf/webmain/72C6FC6CE4AD4D1386256B1800794596
Also, a "quick and dirty" way to control pins on either the serial port or parallel port is by writing to a VISA property node:
Have fun!
Message Edited by tbd on 06-28-2006 11:52 PM
07-05-2006 05:11 AM
07-06-2006 03:17 AM - edited 07-06-2006 03:17 AM
Hi G., COmpa,
The link you provided indicate a TTL level pulse is required. I'd use one of the 6211's counters for this. Check-out the "Gen Dig Pulse.vi" in EXAMPLES.
If for some reason this pulse is too weak, you ought to be able to get a precise pulse using one of the Port 0 digital outputs - check-out "Buffered Pattern Output.vi".
There are also analog outputs available on this board, but it looks like the DIO are capable of sourcing more current - and the buffered [port 0] DIO allows precise pulse duration. Looks like a really nice board!
Cheers.
Message Edited by tbd on 07-06-2006 03:18 AM
07-06-2006 03:25 AM
07-06-2006 06:55 AM
07-06-2006 05:57 PM
thescar--
What to hook the trigger - pin to is really dependant on what this pin is used for. It could be a ground but I would recommend looking in the manual for your device, or getting in touch with the manufacturer. So that you know for sure.
John H.
07-07-2006 12:52 AM
Hi G.,
John is right, you're in the best position to answer these questions as you [should] have all the specs!
However, I'd have said "yes" - trigger- should go to any one of the "D GNDs".
Cheers.
07-07-2006 02:48 AM
07-07-2006 01:25 PM
thescar--
Basically, you will need to call the manufacturer. If they say look at the diagram, tell them you already did and it didn't help. Be persistant. We at NI cannot recommend anything since it is not our instrument.
What happens if you just hook up the signal without the trigger neg pin?? Does it work? I mean it might not be necessary. On the other hand that pin could be a ground. That was my first impression, the same as tbd. Then it would be for a Single Ended Reference connection (one signal one ground for ref.). In that picture it says the tigger signal goes to both, so like a differential connection (both connections are signals and common node voltage is rejected) your trigger signal would be wired to both. I really don't know.
You could play with it but I would HIGHLY recommend getting in contact with the manufacturer first. You could cause a ground loop and break the instrument. It is really up to you. Good Luck.
John H.
