08-17-2013 03:20 AM
Hi J-Spin,
Many thanks for the helps. I get a good result. Beside this, do you know how to put the FIFO SubVI inside a Table Control.
08-18-2013 12:00 PM
@GaBrieLLiao wrote:
... do you know how to put the FIFO SubVI inside a Table Control.
That question makes absolutely no sense. Can you clarify what you mean by that?
(A table control is a front panel object (typically indicator) and cannot contain code.)
02-03-2015 12:45 AM
hey sean
how did you get your thing working
can you explain it ?
i need to add values continuously to a fixed size fifo array
all helps are welcomed
02-03-2015 01:21 AM
AnVajpeyi wrote:i need to add values continuously to a fixed size fifo array
You also need code to remove the oldest element from the buffer, right? (else it won't be "fixed size" :D.
simplest would be to keep a fixed size array in a shift register and keep track of the insert point. Read the oldest value from the insert point before overwriting it with the newest value. There is also the data queue ptbypt tool. What have you tried so far?
