08-30-2015 12:24 PM
Hi All
Help me please resolve the one problem. How to correctly temporarily disable/enable all channels except one in multichannel PID control loop?
Thanks in advance,
Oleg
Solved! Go to Solution.
08-31-2015 05:25 AM - edited 08-31-2015 05:26 AM
08-31-2015 12:24 PM
Hi Greg
Could you provide me some example? I would appreciate if you could take any existing example (may be Multi Channel PID.vi from LabView examples folder) and show me which values I should provide to the manual inputs. I've tried to play with it but unsuccessfully. 😞
Thanks in advance,
Oleg
09-01-2015 01:30 AM
Hi Oleg,
who is "Greg"?
You should provide the values you want to set at manual control. If you want bumpless switching you should provide the last value from automatic control…
Whenever you "try" something you should attach your VI. We will provide hints and comments for improvements…
09-01-2015 05:53 AM
I'm sorry, Gerd. I hope you excuse me for this mistake.
I've sorted out with your idea a more tight. Currently I've decided to use it (see attached picture) for freezing current state.
Thanks you for help.
Oleg
