Reply
How to convert comma-separated-string into numeric-array?
Go to Solution
my 34401 returns 200 values in a string with this format:
-1.42979706E-03,+4.46900451E-03,-8.48235088E-04,-2.17539596E-03,-1.34144462E-03,+4.50590958E-03,-9.78340028E-04,-2.31519575E-03,-1.10844497E-03,+4.70200416E-03,-9.83187455E-04,-2.45499555E-03.....
So the numbers are comma-separated and the doubles have a point.
How can i now move this values into a double-array?
Thanks for the help
Message 1 of 12 (8,642 Views)
Reply
Re: How to convert comma-separated-string into numeric-array?
[ Edited ]
Hi OnlyOne,
easy like this:
20223i6E806FBE09F9FDFD
CLAD, using 2009SP1 + LV2011SP1 + LV2014SP1 (+ LV2016 sometimes) on Win7+cRIO
Kudos are welcome Smiley Wink
Message 2 of 12 (8,632 Views)
Thx for the fast answer but its not working corectly.
The numbers are wrong converted:
For example a:
+2.93120677E-03 is converted to 2 instead of 0,00293120677
Whats wrong here?
Message 3 of 12 (8,616 Views)
Reply
Accepted by topic author OnlyOne
‎08-27-2015 06:09 PM
[ Edited ]
Hi OnlyOne,
you should note that you configured your computer wrongly Smiley Wink You use German/East Europe regional settings with "," as decimal separator and try to convert measurement data using "." instead...
Well, try a format string of "%.;%f" - and read the help for format strings!
When the different format string also fails, you may try this one:
20225iC85653BA6FBF7EF9
Message 4 of 12 (8,613 Views)
Thx for the solution. Both things are working.
Message 5 of 12 (8,596 Views)
Reply
I was working on similar project.  I got to separate two string number as (25 , 124) where first number is temp and second is pressure read from arduino device.  I need to separaye these two numbers and put it into graph as well as store the results in a file.
My readings are as:
24,124
25,167
33,234
and so on...
i could separate using your vi but it puts both in array  .  I was trying to separate it out and put in graph .
I look forward for anyone's help.  If I could get he Vi or detail information on it, I would really appreciate it.
Message 6 of 12 (7,459 Views)
Reply
Use Index Array to get two different 1-D arrays of each column.
Message 7 of 12 (7,455 Views)
Reply
Thank you for the reply. To be honest i am new to this labview . If you could show any example Vi i would really be so thankful.
Message 8 of 12 (7,452 Views)
Reply
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 9 of 12 (7,446 Views)
Reply
Thank you for this post. I had the reverse problem, converting a numeric array to comma separated list of strings.
Message 10 of 12 (6,541 Views)
Reply
