How to convert a string (an indicator with numbers separated by "," : every alternate number is real and complex values of my desired output) to a 2 D array ? And I would like to plot on a waveform graph
Hello Guys,
I have my raw output data from the network analyzer read as a string separated by ",". I want it to be displayed as a 2D array and want to plot it on a waveform graph. I have tried certain things suggested in the forum, but some help is really appreciable.
Thanks in Advance!!!
(3,037 Views)
If it's a 2D array: Is there another delimiter than ","? How will you decide when a line is finished?
Other than that you could use the Match Pattern Function in a while loop to search for the "," and then convert the string before into a number and build it into an array.
Edit: After reading the title again I asumme, you want one column for real and one for imaginary numbers. The solution however, is the same, you could use the match pattern function twice in one iteration, then each iteration gives you one real and one complex number.
Remember Cunningham's Law
(3,026 Views)
Is this what you mean?
______________________________________________________________
(3,020 Views)
I wonder why you want to plot the real and imaginary parts separately? Shouldn't you be better using an XY graph?
Ben64
(2,923 Views)
Ben64
Just to try to keep Ben64 off thr RG thread (Shhh. ) 😄
Somatimes its easier to see IQ data this way
"Should be" isn't "Is" -Jay
(2,887 Views)
