How to convert a grayscale image to 8-bit 2D unsigned integer array
Hi.
The "Color Utilities" function in Vision Development Modulde contains the IMAQ ColorImageToArray, which only has 32-bit unsigned integer values as an output. Is there an option to achieve an 8-bit unsigned integer value in the output ?.
Best regards
Oesen
Message 1 of 11
(5,286 Views)
I would use IMAQ Cast Image
Here you can see what it does.  I would cast to U8.
Message 2 of 11
(5,279 Views)
In your topic subject, you mentioned grayscale to 8bit!! Grayscale images are 8bit.
-You can try converting color(32 bit) to grayscale(8bit) using type cast as GuenterMueller suggested.
-You can also get single color plane (8bit) by simply using IMAQ Extract single color plane also.
uday
Message 3 of 11
(5,264 Views)
Thanks for the reply GuenterMueller
I'm already using this function to convert a 32-bit image to 8-bit image, but the problems is the next step. I need to convert the 8-bit image to 2D array of 8-bit unsigned integers.
Best regards
Oesen
Message 4 of 11
(5,263 Views)
I need this function, but as a U8 output instead of U32
Best regards
Oesen
Message 5 of 11
(5,254 Views)
First convert your color image to gray scale by one of earlier methods and then Use IMAQ image to array
uday
Message 6 of 11
(5,253 Views)
Hi Oesen.  Use IMAQ Extract.
Message 7 of 11
(5,247 Views)
Hi GuenterMueller
That function configures the image. My image is converted from 32-bit RGB to a 8-bit Grayscale as shown in the picture below. I just have to configure the data type of the 2D output array from a 32-bit to a 8 bit.
Best regards
Oesen
Message 8 of 11
(5,229 Views)
As uday said above, use image to array after you have extracted the red color channel.
Message 9 of 11
(5,221 Views)
Accepted by topic author Oesen
Please check this. what you have done is not correct(according to me).
-Please use proper wordings for image types
Color-32bit
Gray-8bit
-Intype casting you are using conversion to RGB(U32), Image type should be grayscale there according to your requirement. If the image is color why do you need to typecast again it to RGB??
-After extracting color plane, it is no more color(32bit) image.There is no point in using color image to array. use IMAQ image to array instead.
uday
Message 10 of 11
(5,209 Views)
