How to convert a data logger the reads analog inputs to a datalogger which reads both analog and digital inputs
Iam using NI Datalogger which reads only analog inputs.But now i want to convert the same datalogger to read both analog and digital inputs.How can i do this.As Iam beginner in this field kindly give me detail explanation.any examples are welcome.
(2,351 Views)
Depending on the hardware you have that can be done pretty easily. Do you know what device you have?
-scraggs99
(2,344 Views)
Iam using NI PCI-6071E DAQ board
(2,327 Views)
there is no possibility to measure digital signals with the NI Datalogger delivered with NI DAQmx base.
You can have a look to the LabVIEW Example finder (Help --> Example finder) to find a example. Your board does support Traditional DAQ and DAQmx.
You could create a Task in DAQmx. Go to LabVIEW, choose a DAQmx Task constant, choose the task, right click --> create programcode --> example to generate a easy program. Than you can change it to write the data into a file.
Matthias K
(2,308 Views)
