05-01-2012 07:35 AM
Hi
I am trying to connect a bluetooth device to labVIEW. I am using a bluetooth create listener function and it asks for UUID and that it has to be in GUID format. I would be grateful if anyone could kindly let me know how this conversion is possible. I was unable to find an answer to this question so far.
Thank you
T
05-02-2012 11:41 AM
Hi Tewerz,
You should be able to assign your own GUID.
uuid Identifies the service. You can assign duplicate UUIDs, but National Instruments does not recommend assigning duplicate UUIDs. If a Bluetooth client requests a UUID that multiple services use on a Bluetooth server, the server uses the first UUID it encounters. The UUID must be in GUID format. An example of a UUID in GUID format is B62C4E8D-62CC-404b-BBBF-BF3E3BBB1374.
Here is some information on UUID and GUID:
http://www.famkruithof.net/guid-uuid-info.html
DylanC
05-07-2012 12:02 PM
I already have a bluetooth module I want to pair with. I use a bluetooth discover and got the address. How do I translate this to UUID in GUID format or these have no relation?
Thanks a lot!
05-08-2012 09:08 AM
Tewerz,
You need to assign the GUID yourself. You should be able to choose anything you want as long as it is in the format: B62C4E8D-62CC-404b-BBBF-BF3E3BBB1374
DylanC
06-15-2012 07:04 PM
Hi DylanC
Do you know if is the same proccess to use a laptop bluetooth device?
06-18-2012 08:39 AM
What do you mean by laptop Bluetooth device? If you are connecting to any device over Bluetooth it should be the same process.
DylanC
