06-08-2007 02:56 AM
06-08-2007 03:10 AM
What do you mean by "ability to control RS232 interface? If you meant transmitting and receiving via RS232, yes you can do it in either 7.2 or 8.1. You can start by going to the examples loaded with LabVIEW....Help--Find Examples---Serial. You can find bunch of examples on how to communicate on your serial port.
06-08-2007 06:41 AM
02-04-2011 05:32 PM
i have a question i am wanting to control an rfid reader/writer that has a RS232 or USB connection through labview. Here are some specs on the product. is this possible for it to work.
02-04-2011 05:46 PM
LabVIEW supports RS232. It doesn't matter what is on the other end of the cable. LabVIEW doesn't know or care. You just have to make sure that you understand the protocol for your device.
02-07-2011 11:39 AM
Steve is correct. I would recommend RS232, unless that company has a USB driver for labview. Trying to write your own can be complicated. This is a taster of the issues. It is definitely possible, just more difficult.
When you do have more questions about controlling an instrument, I would recommend making a new thread in the Instrument Control (GPIB, Serial, VISA, IVI) forum.
02-08-2011 09:07 AM
alright, thank you for all the feedback, it was very helpful, and i will be sure to post in the correct forum when i recieve the hardware and have more questions.
05-28-2014 09:28 PM - edited 05-28-2014 09:30 PM
Hello Guys, How I send LOW LEVEL for VISA SERIAL WRITE??
05-28-2014 10:43 PM
What do you mean by "LOW LEVEL"?
This thread is over 3 years old. You should start a new meesage threads and include details that explain your message.
02-18-2015 01:36 PM
I need to know how to use rs232 to implement it with labview for alu in vhdl
