03-14-2017 01:03 PM
ramialsaiad wrote:I have cDAQ-9172 here is a picture : https://www.google.se/search?q=c+series+modules+ni+instruments&source=lnms&tbm=isch&sa=X&ved=0ahUKEw...:
Does that help in producing a signal of 1MHz?
That is a sales picture. The cDAQ-9172 is a cDAQ chassis. What modules do you have in it? Anyways, it will not help because there are not any C-Series modules that can produce your 1MHz sine wave.
03-14-2017 01:03 PM - edited 03-14-2017 01:06 PM
@ramialsaiad wrote:
@crossrulz wrote:
@ramialsaiad wrote:
I have something called "national instruments hi speed usb carrier" http://sine.ni.com/nips/cds/view/p/lang/sv/nid/204178 and another thing called "national instruments ni cdaq 9172" similar to this http://www.ni.com/sv-se/support/model.cdaq-9174.htmlCan I use them to generate 1 MHz instead of the things you mentioned above?
Both of those are just chassis. They need a module in order to do anything. And I am not seeing any C Series modules that can output a signal above 51.2kHz (Niquist states the highest bandwidth signal you can output is ~25kHz). So that will not work for you.
Hi
Thanks you all
That link only shows some NI products. I repeat, the cDAQ-9172 is ONLY a chassis! Do you have a module inserted into it, or not?
Edit: please read a bit this page: http://www.ni.com/compactdaq/whatis/
It explains what is "chassis" and what is "module".
03-14-2017 01:24 PM - edited 03-14-2017 01:25 PM
"there are not any C-Series modules that can produce your 1MHz sine wave" this is the final conclusion of my question's answer.
Now I know that I have to use a real generator to generate my 1MHz sine wave
Thank you very much
03-14-2017 01:27 PM
@Blokk wrote:
@ramialsaiad wrote:
Hi
Thanks you all
Mr crossrulz's answer was the final conclusion and he said that there is no c series can produce 1MHz sin sigal..
Now it is clear for me
Thank you very much
03-15-2017 04:59 AM - edited 03-15-2017 05:00 AM
Hi
I have a device called ni9263 http://www.ni.com/sv-se/support/model.ni-9263.html , I can not use it do generate the 1 MHz frequency which I mentioned yesterday !! I just want to be sure now about that
thank you
03-15-2017 05:52 AM
I'm sorry, but do you know how to read specifications? The product clearly states it can go up to 100kS/s/channel. Is 100kHz faster than 1MHz? NO!!!
