How to configure several counters and out terminals in one task?
I use NI USB-6341 board and it has four counters. I want to configure several pwm generations with different duty and frequency in one task.The vi which I made below can not generate any pwm signals.I hope someone can teach me how to configure! Thanks in advance!
(2,790 Views)
Accepted by topic author mingren1238
I won't swear to this nowadays, but time was when you could not include more than one counter (configured differently) in one task.  NI-DAQ wouldn't allow it.
If you try, you get an error - what error code do you get?
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
Blog for (mostly LabVIEW) programmers: Tips And Tricks
(2,678 Views)
The error code is 89137,the error happens in DAQmx Start Task.vi:722001. Specified route cann't meet the requirement.
thanks!
(2,646 Views)
But I want to synchronize two counters and need to change the PWM duty in every loop. How can I ensure the two counters generating PWM signals synchronously. I have read the examples on this forum using AI input and digital trigger,but situations are different.Waiting for your reply! Greatly apprecited!
(2,640 Views)
The picture shows my needs!
(2,638 Views)
