Hi
A LV Waveform consists of a starttime (x0), a time-difference between eacht datapoint (dt) and the data (X).
So if you want to writa a waveform-file, you have to create a waveform using this information. So extract these data from your text file, convert it (if necessary) and create the waveform.
Hope this helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
