How to cleanly remove subvis from owning class
I would like to delete a couple VIs from an owning class.  They are dynamically dispatched VIs.  I've found that some VIs have a "Remove from Project" right-click option while others don't.  They also don't have a File>Disconnect from Library option.  What's the best way to remove them?  Deleting them from disk causes LabVIEW to have a cow...
Worth mentioning the class is in an Auto-populating folder.
Thanks, PattyD
Message 1 of 8
(4,333 Views)
In the project explorer, can you drag the vi out of the class and then save the vi and the class and then you could be able to delete the vi.
Message 2 of 8
(4,292 Views)
I typically just delete the VI from the class/library, save the VI when prompted, then delete it from the disk.
GCentral
Message 3 of 8
(4,271 Views)
@crossrulz That first step is what I'm unable to do.  How do you delete it from the class/library?  Hitting delete does not work.
@dkfire, It does not allow me to drag it out of the class unless i drag it into another class.  I'm a little stumped here.
Message 4 of 8
(4,250 Views)
".lvclass" files are actually just text files with XML in them.  If all else fails, open them with a text editor, and delete it from the XML directly.
Message 5 of 8
(4,244 Views)
That must be an artifact of the Auto-populating folder because I have been using the delete key to remove items from classes quite a bit lately (LabVIEW 2016).
GCentral
Message 6 of 8
(4,240 Views)
I suspect you are right crossrulz, but stopping the folder from auto-populating, saving, and reopening the project does not allow me to delete the files.  I would think that if auto-populating were the culprit this would fix it.
I will probably have to edit the lvclass file manually as Kyle97330 suggested.  I was hoping for something a little cleaner and included in LabVIEW though.
PattyD
Message 7 of 8
(4,232 Views)
Accepted by topic author PattyD
After a quick chat with NI we figured this one out.  I actually had another VI with the same name in my project (whoops).  Because of this, it wasn't allowing me to remove it from the class because then I would have two VIs with the same name in the project.  The solution was to rename them and then delete.
Message 8 of 8
(4,209 Views)
