11-17-2010 05:43 AM
Hi Guys,
I have to build an application which is used to check the CPU usage and Paging using LabVIEW. How do i do it??
any help, suggestion or hints will be greatly appreciated..
Prashant
Solved! Go to Solution.
11-17-2010 06:28 AM - edited 11-17-2010 06:35 AM
If you are planning to design your application for Windows you can use the .NET classes. (System.PerformanceCounter), there is a simple example shipped with LabVIEW :
C:\Program Files\National Instruments\LabVIEW 2010\examples\comm\dotnet\SimpleTaskMonitor.llb
Also you have several VIs that you can use to check infos about the processor.
11-17-2010 07:13 AM
Hi Maxime,
Thanks for your help. Is there any other method so that i don't use .net classes and still achieve it?
11-17-2010 08:20 AM
