09-24-2014 12:14 PM
LV2013
Is there a way of changing the scale label positions at design time? The only way I can find to move them is programmatically which is not convenient.
Surely it should be possible to just grab them and move?
Solved! Go to Solution.
09-24-2014 01:36 PM
Right click >> Advanced >> Customize >> change the tool to the one showing the tweezers and you can manipulate the individual elements such as the scale label.
09-24-2014 01:48 PM
But then I think you have to save the control as a new control which isn't what I want to do.
09-24-2014 01:50 PM
No. You don't have to save it. But you do need to tell it to replace the original control that exists in the VI.
09-25-2014 08:31 AM
Thanks, that does work.
Unfortunately the warning about unsaved changes will be lost is somewhat misleading.
