Looks like to make table cells transparent you have to run the VI at least once with the CellBGColor property. Wire the color constant into it (can be found in the numeric palette) and select the color to be T (top right). You also need to select the active cell.
You may also need to click to select the paintbrush, right click one of the cells and select T there.
Does anyone know why this is so? Why does selecting T with the paintbrush not turn the cells transparent (at least in 7.0)?
___________________
Try to take over the world!
