How to change the color of a Tab Control
(3,440 Views)
You can change it with the Coloring tool, just like with any other control.  But if you dropped a Dialog Tab Control, you cannot change its color.  Make sure you dropped a normal Tab Control (from the Containers subpalette) and not a Dialog Tab Control (from the Dialog subpalette).
Good luck,
-D
(3,430 Views)
Hi CEY,
If you need to change the color programmatically, you can use a property node, and select Color»FG Color Or BG Color.
Hope that helps,
AG
(3,414 Views)
