04-04-2008 03:21 AM
04-04-2008 03:32 AM
04-04-2008 03:35 AM
Hi Jan,
you have to allow different colors, then use the page references and change the color. See the attached example.
Mike
04-04-2008 04:11 AM
09-24-2008 08:58 AM
I have LV 8.2
Your tab control has two color red and green, each color for each tab on the front panel
I only found my tab control in the "container" palette, and only one color for two tabs.
where do you find your tab control with one color for each tab
I like your tab control
09-24-2008 09:07 AM
09-24-2008 09:12 AM
BTW, you have to right-click the tab controls edge, then select 'Advanced >'. You'll find it there.
Or, you can do it programatically with property nodes.
10-12-2008 02:25 PM
ok i'm missing something here no matter how many things i have tried i cannot get the tab control to change color. i have set it for multiple colors it just doesn't want to change.
i tried duplicating the example in my vi but am having difficulty adding the page property node.
when i do have a property node that appears correct i cannot connect it to the tabctrl property node.
so basically what i wish to know is what step am i missing.
10-12-2008 02:54 PM
08-13-2012 08:10 PM
Okay i have a similar issue. How do you change system tabs color? I keep getting errors. Ended up moving to modern tab to make it work. But i like system tabs look better. Is there anyway to do it on the system tab?
