How to change (animate) icon of currently running VI
Dear forum,
I currently try to use a LabVIEV VI as a simple sequencer: Several (very slow) actions have to execute one after another. Each action is represented by a Sub-VI, some actions are executed several times. While the main VI is running, the currently executed Sub-VI (and only this one) should be highlighted as its icon is changed or animated in the block diagram (like when you pause the execution of a VI).
With scripting enabled I modify the VI icon with the "VI Icon.Get as Image Data" / "VI Icon.Set from Image Data" invoke nodes (see attached exmaple in LV 2014: <Main.vi> calls <ChangeMyIcon.vi>). Works great, but when I implement this VI multiple times into a main VI (like my example), ALL of these VIs begin to blink when ONE of them is currently running.
Is there any way to modify only the icon of the running VI, even if I use the VI several times? I tried to make <ChangeMyIcon.vi> reentrant, with no luck.
cpschnuffel
(2,869 Views)
You didn't attach the example.
Ben64
(2,862 Views)
Hi Ben64,
I tried to attach the VIs directly, but that didn't work. Maybe with this zip file?
cpschnuffel
(2,860 Views)
The VI icon belong to the "master " version of the VI, so even if you make them reentrant all the clones icon will be modified.
Ben64
(2,850 Views)
But LabVIEW does something similar with the VI icon when in pause - and that only with the one becoming active. How do they realized it?
cpschnuffel
(2,840 Views)
