How to change X-axis scale in real time mode
Hi.
We're having a problem determing the X-scale on a chart. The chart shows a sine-wave in real time scale, with about 1 second or so on the graph. How can we change this to 10 or 30 seconds? Which property node should we use for this, when the chart uses real time scale?
Thanks for your help!
___________________________________
Is my avatar the dog from the fraggle rock?
Message 1 of 13
(7,534 Views)
for charts: set proper history length and choose autoscale for x axis...
What is a "real time scale"? Do you just mean to display x-axis formatted for time display?
Message 2 of 13
(7,531 Views)
The chart uses X-axis with the exact date and time from the computer - T0.
If we change the chart history length and then "autoscale X-axis", nothing changes.
Do you know any property nodes that will can change the lenght of the X-axis, when it shows the exact time?
Message 3 of 13
(7,527 Views)
Added two pictures that shows the problem.
Message 4 of 13
(7,526 Views)
you don't need to set T0 constantly. The x axis range is settable: simply switch off autoscaling and set the needed range (either manually or by property nodes). Then this range will not change with new data arriving!
Next time please attach a (simplified) VI instead of undebuggable pictures...
Message 5 of 13
(7,519 Views)
The VI is quite large, with lots of subVI's, so adding it here, might be problematic. But it's added now. All the charts should use absolute time, and be scaled in for example 10 or 30 seconds.
We have tried using property nodes, with "X scale - max/min" and "scale fit", but the problem is that the X-axis is in absolute time.
Eventhough we remove "autoscale X-axis", it's not possible to type the time manually - it just switches back.
Thanks a lot for your help.
Message 6 of 13
(7,515 Views)
An older version so you'll be able to open it Smiley Happy
Message 7 of 13
(7,514 Views)
I have the same problem with changing the x aix period. It only shows 1 second on the chart and backwards. Did you figure out how to change to longer period?
Jingjing
Message 8 of 13
(6,655 Views)
Yes we solved it back in 2011, but I don't remember how. Probably using property nodes.
Message 9 of 13
(6,651 Views)
thanks for the quick reply!
I am new to labview and we are using limited edition because we haven't decided to buy windows or labview. I am wondering if the property nodes are in the full edition? (I didn't find the property nodes for x axis)
Message 10 of 13
(6,642 Views)
