09-11-2009 04:17 AM
Hi Dan07,
i can't see the problem. Your attached code works for me.
Where do you have the problem?
Mike
09-11-2009 01:24 PM
Hi Mike
The code is working very well but I am trying to activate the "path out" field to get the full path of the shell32.dll that was used by the VI, and this is not working.
Dan07
02-24-2016 08:11 PM
this post is almost 7 years old now, is this still the best way to browse for a folder? I see in LV15 the native File Dialog is improved, but what about LV11?
Anyone knows how to set the start path using this dll?
02-25-2016 02:14 AM
I don't really need to browse for folders, so I never really played around with this, but I think the start path is more of an issue. The relevant search term you should add is "pidl", and you might find that people have implemented it. There are certainly other threads showing calls to this function, both here and on LAVA. There may also be a .NET version, which would be easier to use.
A third option would be to implement this yourself using a tree. You basically do a List Folder when the user opens a branch to see what's under it. If you want to improve performance, you can even prefetch the folders of all the children N levels down from where you are, so that when the user opens a folder, the results are immediate. If I would do that, I would probably offload the processing to a parallel loop and send results back as they come to avoid delaying the UI.
02-25-2016 05:24 PM
The good suff is here: https://lavag.org/topic/7033-browse-for-folder/#entry66623
using .NET, supports initial path
