How to bundle a queue?
I've used bundle before on regular data types etc
Can't seem to work out how to bundle a few queues into one?
Mainly for aesthetics on the block diagram, so I can pass the bundle into my SubVIs and unbundle and use as necessary?
Tried connecting queues into both 'bundle' and 'bundle by name' but with no joy? Or is that off the ball totally?
Cheers 🙂
Message Edited by Michael Burgess on 03-31-2005 03:04 PM
(2,764 Views)
It seems to work fine here...
Paulo
(2,755 Views)
Ah - sorry - I was thinking back to a problem a couple of weeks ago that i'm readdressing - remembered properly now - I can bundle them like that, but let's say I wanted to feed that bundle wire into a subVI - is that possible?
If so, what 'control' or 'indicator' do I need to drop onto the subVI front panel / block diagram to wire to on the connector pane?
Cheers
(2,752 Views)
The easiest way you can do that is right click on the wire between the bundle/unbundle and choose create control.
Place the control that comming out of this in your subvi and then you can connect them.
Paulo
(2,745 Views)
I would start by getting all my ques into a bundle, then I would right click on the bundle and create an indicator this will have all the ques references in it.Then I would copy it into the subvi and make a control for it. Here is an example I threw together.
Joe.
"NOTHING IS EVER EASY"
(2,741 Views)
cheers guys 🙂
(2,733 Views)
