09-25-2008 01:35 PM
I'm executing Particle Analysis Report VI on the thresholded image that could or not contain particles. An array of clusters is returned and contains specific information for each particle (table of detected objects). I need to work with only 2 informations (orientation and height dimension) of each particle, but I don't know exactly how to do it. The purpose of vi is to record an avi file if these parameters fits inside/outside a certain value, during a real time acquisition.
How can I analyse all particles at the same time, once the report could send me an empty result or hundred particles found?
10-13-2008 01:10 PM
Please take a look in the following links, they can help you to solve your issue:
http://zone.ni.com/devzone/cda/tut/p/id/3169
http://zone.ni.com/devzone/cda/epd/p/id/5629
http://zone.ni.com/devzone/cda/epd/p/id/1517
If you have any question please contact me.
Thanks.
Luciano Borges
National Instruments Brazil
