07-05-2005 10:34 AM
07-05-2005 10:48 AM
07-05-2005 11:09 AM
07-06-2005 03:25 PM
07-06-2005 03:25 PM
08-31-2005 09:06 AM
08-31-2005 12:00 PM
To convert a thermocouple voltage into temperature, you would have to build an amplifier circuit using two op amps. The first op amp would have a potentiometer from the positive input to ground, the second op amp would have a potentiometer from the output to the negative input (feedback resistor). Then you would have to repeat the following: Put the thermocouple in ice water and wait a few minutes. Then set the first potentiometer to read 0 volts on the output of the ciruit (0 degrees C). Then you have to move the thermocouple to a pot of boiling water and wait a few minutes. Then set the second potentiometer to read 10 volts on the output (100 degrees C). This will upset the 0 reading so you have to repeat the process several times. After doing this, 0 volts will be 0 degrees C and 10 volts will be 100 degrees C. To convert from volts to degrees, just multiply by 10. Use a DMM or Analog Input board to measure the volts. Labview can communicate with the DMM through GPIB.
So you see, this is a long drawn out process. Instead of using a thermocouple, it would be much easier, and also cheaper considering the time involved, if you were to just buy a temperature device that already does this.
08-31-2005 12:56 PM
Except that the boiling point of water depends upon altitude and barometric pressure. This can be 5 to 10 degrees C in some areas.
Also, this does not account for parasitic thermocouples. The DMM lead to the first wire of the real thermocouple forms parasitic thermocouple where it touches that wire - as does the return lead from the DMM to the other thermocouple wire. These two parasitic thermocouples are at the temperature of your terminal block (presumably "room" temperature) - which could vary 10 degrees C or more, depending upon whether you take this outside. The only way to account for this is to have an isothermal block, measure its temperature with a thermistor, and subtract the parasitic thermocouple voltage characteristic.
On the other hand, if this is meant to measure hundreds of degrees C, rather than just 0-100, then room temperature may be down in the noise (and the calibration routine would need to be adjusted for the wider range).
-- Les Hammer
09-01-2005 10:39 AM
09-01-2005 03:32 PM
